Results 131 to 140 of 1575
- Aug 2009
- 1,553
October 18th, 2010 01:42 AM #131
- Aug 2009
- 1,553
- Aug 2009
- 1,553
October 18th, 2010 01:49 AM #133generally its ok to not clay and go directly to swirlX but if its a bad case of breakdust or industrial fall out on the paint, those which feel like very sharp dusts you might want to clay since applying swirlX might push these around and create more scratches, but generally it would be ok to remove clay from the procedure it really depends on the paint condition
To Nik: i agree with the second paragraph, im actually a bit let down by what Mike Philips said because we really did an actual test on which one lasts longer, NSC on bare paint or NSC on a glazed paint we you could really see the sheeting gone with the glazed paint thats why we have acrylic, polymer and urethane based glazes hanging around, these are designed to work as a glaze that is compatible with whatever the nature of the sealant is, generally polymer based and acrylic glazes really work well with sealants.
- Aug 2009
- 1,553
October 18th, 2010 01:54 AM #134with some sites they are very strict with their standards as with our mentors standards, so we were taught to clay first before using any machine on the paint to remove embedded dusts that might cause more swirls, but to be honest it really all depends on the paint condition, you would see some detailers out there winning trophies and plaques for detailing but they don't even know what a clay is.
with the IPA its always better to do IPA so that NSC cleans better, its like taking away a huge portion of NSC's job enabling NSC to perform better, like with what indiej said its an optional step but a highly recommended one
the routine looks nice but the application of step 2 might cause you bonding problems with the sealant
- Aug 2009
- 1,553
October 18th, 2010 02:03 AM #135hmmm i don't think wet sanding the paint is such a good idea, i mean even though you use the finest 3500 grit sand paper you are taking out more clear coat compared to a premium rubbing compound, so im not comfortable with the idea
next step 2 and 3 are quite puzzling, you see in the first place why would they machine buff the paint if they are applying overcoat? by overcoat im guessing you mean clear coat, you see you only machine polish when you are ready to deliver the vehicle or you machine polish a paint to make it generally leveled, leveled to a point that when you do a uniform method of wet sanding you get better results, usually when people machine buff a car its 95% to be delivered to the customer and the remaining 5% is to be wetsanded again to be layered with clear coat, you see you need to wetsand the paint in order for the clearcoat to stick properly to the paint, the adhesion is better this way but it also means that you are going to wetsand the paint meaning removing them, now however thick the clear coat they plan on applying i dont know but my guess is that they will wetsand the paint with 2500 or 3000 grit sandpaper and just polish it, true they might not use rubbing compound but they might end up using an aggressive polish with can also remove clear coat as much as rubbing compounds can
October 18th, 2010 02:13 AM #137
Siguro yung mga floating paint particles sa hangin yung dumikit sa paint.Kung light overspray lang yan meaning hindi directly tinamaan ng sprayer pwede matanggal ng clay yan. Nung galing body repair ako dati ang daming gaspang sa different panels ng car. After claying makinis na ulit
October 18th, 2010 02:34 AM #138
Originally Posted by [URL="http://tsikot.yehey.com/forums/member.php?u=76971"
1. Step 1
2. Step 2
IPA (or hindi na kelangan)
3. Sealant
4. Wax ( after 12/24 hours )
with regards to layering the sealant pala ms madkatz kelangan ba talaga hindi gamitin yung car or much better during the curing time eh wag gamitin...
October 18th, 2010 03:18 AM #139
ms madkatz,
when i said overcoat it means that they will apply clear coat again after doing those steps that i mentioned.
so anong magandang gawin ko:
- ipasok ko sa kanila then gawin nila yung steps mentioned above?
- ipasok ko sa kanila with a different procedure that this group may suggest differently from the steps that they suggested?
- or wag ko na ipasok sa kanila and ako na lang mag clay?
ang habol ko lang sa totoo lang is malibre yung procedure coz pasok pa sa warranty and HARI told me that they will address my concern.
pwede rin ako mag clay yunl ang sayang yung libreng procedure...
thoughts please...
- Aug 2009
- 1,553
October 18th, 2010 04:35 AM #140
