Results 11 to 20 of 38
August 30th, 2018 03:05 PM #11
OK... I can now see what you're looking for... Sadly, I don't think we have what you need locally...
Normally, small industries you will see will fabricate something from you that's made of steel - which will be too heavy
We have local shops that can weld/fabricate aluminum, but I think the metallurgy is not yet there.
(Even yung local steel natin is not as good as the Japanese/Europeans, heck even the Koreans and Chinese cannot compete with them)
To have something that compares with the brands you mentioned, you will need carbon fiber...
Next, local registration... I think you will need a proper chassis number (used by OTJ, Trucks and PUJs), body number for cars... If you build your own... Walang basis and LTO for documentation.
If performance is not required (ok na yung looks), hanap ka lang ng magaling na latero...
- Feb 2014
- 2,658
August 30th, 2018 03:25 PM #12get a civic type-R crate engine
TIG welded chro-moly steel tubing
doable
better yet make it electric
- Aug 2018
- 28
August 30th, 2018 11:15 PM #14That is exactly how the prototype chassis will be. Albet, mid engined. I am still designing the rear engine cradle but as for the passenger compartment and front suspension box it is well set up. I would be using square tube, however i would prefer round but for now I need a test bed chassis for prototyping drivetrain and construction purposes.
I heard of the jeepney shops but I am still trying to locate the welders for them and see if they could point to someone who could assist me. I would like the tubing to be 308 stainless steel, which would be further powder coated for extra degree of rust prevention for now.
- Aug 2018
- 28
August 30th, 2018 11:18 PM #15Understood, will keep that in mind. I was in talks with a welder who quoted me all that he would need but the fact that I would need to ship the chassis from Manila to Mindanao for assembly kind of scared me so I am not looking for people closer. I might put an ad up again on the facebook groups and see if anyone is interested.
- Aug 2018
- 28
August 30th, 2018 11:21 PM #16
- Aug 2018
- 28
August 30th, 2018 11:30 PM #17Actually, not quite. Noble, BAC, Radical, and even Ariel are creating cars from steel tubing. The trick is in the chassis design and tubing used.
Dont worry I wont need welded aluminum in the chassis just welders that could work with stainless steel and possibly chrome moly, but if I used that in would need to heat treat it to prevent it from being to brittle afterwards.
Yes I am still studying what would be required by the LTO to register it. Since I would have the cars road tested before being delivered to customers and dealerships.
For now though the steel tube chassis should suffice. But i am already working on a composite monocoque chassis idea that if works would allow the car to be built in a few shorter days and allow thr technicians time to focus more on the fit and finish of the car.
However the rear subframe would still remain steel for crash safety and modular use of the tub.
- Aug 2018
- 28
August 30th, 2018 11:35 PM #18When I was first starting this project i had the idea to build an open top roadster, in the same way that the Europeans were building their track day cars. However after I took into consideration the environment, weather, and various unique factors to the Philippines. I made a new design which is now a closed top coupe. The first design would of been with the Civic type r engine. Since the money saved on interior appointment would be directed to the drive train but with the change in design i also changed direction on the engine.
Furthermore Honda is only releasing the Type R engine to racing programs. So I looked else where and decided to go a hybrid route for this vehicle to gate Euro 4 compliance for export into the EU and America.
If the welders i hire can heat treat i would be glad to work with chrome moly but if not 308 ss it is.
- Aug 2018
- 28
August 30th, 2018 11:37 PM #19
- Feb 2014
- 2,658
August 31st, 2018 12:04 AM #20you sure about stainless? it's about as weak as mild steel. probably more brittle than mild steel when welded.
as for the weldable aluminum alloys they need heat treatment which involves a quenching tank
i'm now building an electric dirt bike from scratch. all-original frame design and motor placement. i chose mild steel
Tesla Philippines
