Results 1 to 10 of 279
Tsikot Member Rank 4
- Jan 2003
- 1,403
- Jan 2003
- 1,403
- Jan 2003
- 1,403
June 25th, 2007 11:03 AM #4
A bit expensive for such a minimalist vehicle. I believe that for a sporty three-wheeler to sell in the Philippines, it must not cost more than the cheapest brand new four-wheeled car.
- Jan 2003
- 1,403
June 27th, 2007 07:37 AM #5*wildthing
one of the original group advocates is ehnriko, who has designed a three wheeler sports car - http://ehnriko.bravehost.com/concepts/trima.htm (gt250)
He is currently based overseas but is planning to come back end of July. I am planning to order one unit from him, pending registration and safety issues. (Reckless bus drivers might easily miss its low profile.) Exact configuration will depend on the price.
June 27th, 2007 08:12 AM #6
On this Trima vehicle, since it is supposed to work off a motorcycle engine, I'd like to ask a couple of questions...
1. Aren't motorcycle engines much more polluting than your standard auto engine?
2. Can a motorcycle engine operate an A/C unit's compressor?
3. Seems to me the safety features were more implied than explained. I'd like to know what safety features will keep such a low profile vehicle from being run over by a bus or crashing and sliding under a truck. Just thinking in philippine traffic/road conditions terms....
BANNED BANNED BANNED
- 3,790
June 27th, 2007 08:30 AM #7in my views:
1) Motorcycle engines na 2 stroke are bad... in terms of air pollution than 4 stroke... but they are definitely polluting less (being single pistons) than car engines that are 6 cylinder.
2) yes motorcycle engine can operate a/c unit BUT with limits... RPM of engine and torque of the engine.... I think mahihirapan ang small displacement motorcycle engines to run an a/c lalo na kung single cylinder lang ito and it is running a cargo load at the same time. Yun ngang 3K na makina ng toyota which is 1200cc hirap pagmeron aircon yung oto.... (pero mabigat din kasi yung load ng toyota na car).
3) your risk of being run over by a bigger vehicle with a stupid driver remains the same when you are riding a motorcycle or a bike in the streets... the key is not to make the car TOO small (like a go-kart) and use all necessary safety precautions (like brightly colored, signal ligts, light reflectors, headlights etc).
- Jan 2003
- 1,403
June 27th, 2007 08:30 AM #8*wildthing, ogpro,
Unfortunately I don't have the answers to your questions although I do share your concerns. That is why I am waiting for ehnriko to come home so that I can ask the same questions.
However he does get to log on from time to time. Hopefully he might see this thread and answer the issues before then.
In the meantime, good luck!
Actually am surprised the rest of the gang haven't jumped in - drey, safeorigin, proxies, foifoi05, oyIL, where are you guys?
June 27th, 2007 09:20 AM #9
June 27th, 2007 09:36 AM #10
What about compared to a small 4 cyl which is what it will most likely be compared with?
Zactly. An engine that is straining is also less efficient and more polluting.
I would not put this Trima on the same level as motorcycles, just because it has a motorcycle engine.
The thing is, with a motorcycle, you are mostly alone and are MORE careful. People will have the tendency to assume the added safety when surrounded by 4 walls, and will operate the Trima with relatively less care at higher rates of speed. Not only will this vehicle have the capability to carry a passenger (an extra life to worry about) but its bigger footprint will also be occupying the same roads as other much larger 4-wheeled vehicles. It stands to reason that it will figure in more fender benders than your average MC. I'd consider impact protection not just from OTHER cars but also in the case of the Trima hitting another vehicle or stationary object. Safety equipment can mean the difference between just a dented body panel or a broken leg.
