Results 31 to 40 of 197
December 3rd, 2012 11:16 AM #31
personal preference ko lang yan... mura lang naman over the counter coolant like caltex and the likes eh...
the baldwin supplemental coolant additive cost just 250 pesos.. will treat 16 gallons per pint...
tapos protected na yung cooling systems mo...
- Aug 2005
- 553
December 3rd, 2012 11:23 AM #32
December 3rd, 2012 12:20 PM #33
Q lang mga gurus. Is it necessary na lagyan ng distilled water yung radiator after flushing the old coolant para "ma-drain" ng husto bago lagyan ng new coolant?
Or drain the old, then pour the new coolant pwede na?
December 3rd, 2012 12:24 PM #34
- Aug 2005
- 553
December 3rd, 2012 12:55 PM #37
nosebleed! bloody english man!
well, as for my "practice" - once or twice a year, i drain the rad of my 15yr old car.
1Gal(2L lan ginagamit) of wilkins distilled water + 2 liter of Prestone Coolant (concentrate). 50:50 mix.
My car's rad usually consumes 1Gal++ kapag fully drained. OEM Aluminun plastic top (Calsonic).
Then the premixed solution na prestone din, 500ml goes to the reservoir.
1-2x a week of visual inspection helps too. Sometimes at the morning before i start the engine -
i open the rad cap, start the engine and observe the water sa rad. Rev ng konti at tingan kun sumasabay ang tubig,
this way for me is for checking for my water pump. Dito ko rin tinitingnan kun me mga dumi-dumi na yun tubig.
Check the hoses too, pinipisil ko eto when cold and determine kun palitin na.
ooops cooling system na pala eto.
December 3rd, 2012 02:21 PM #38
- Aug 2005
- 553
December 3rd, 2012 02:27 PM #39
December 3rd, 2012 02:47 PM #40
Unang beses ko iddrain to sir. 5 yrs na kasi and recommended sa manual kada 5 yrs papalitan. Mula bnew di sya nabawasan sa reservoir.
What do you mean by rinse? With distilled water pa rin ba although di na pupunuin yung rad? Sorry got a bit confused there. Btw still planning to use OEM Toyota Long Life Coolant.
