Results 1 to 10 of 12
- Aug 2010
- 86
May 4th, 2013 09:01 PM #1Mga Sirs,
Pinaservice ko yung aircon ng ride ko (Honda CRV 2003 AT) kasi may time na nawawala lamig ng aircon.
- linis evaporator
- palit expansion valve at drier
- nag flush din ng condenser
After ng service ganun pa rin at parang mas lumalala pa. Dati kc, pag ung time na may lamig aircon, nagtutubig pa yung hose sa may engine bay. After ng service, di man lang ma feel na lumamig yung hose. Ang ginawa, nagdischarge konti ng freon at nag improve ng lamig. Pero bumibitaw agad yung compressor at ang tagal bago mag-engage ulit. OK naman yung aux fan.
Pag nag-engage compressor (pag nakaidle), nanginging yung engine at kadalasan bitaw yung compressor. May nagrecommend na ayusin daw muna idling (palinis ng servo) para pag nag-engage compressor kakayanin ng engine.
Baka may same experience kayo sa CRV, patulong naman.
Salamat po ng marami.
May 4th, 2013 09:22 PM #2
did you try checking the relay? sakit ng Honda yan bumibitaw yun magnetic clutch...or yun washer paalis mo na lang, baka malaki na yun gap......yun sa washer pwedeng dukot lang yan P200 lang siguro labor..
May 4th, 2013 09:24 PM #3
Imho, yung aux fan mo boss may tama na. Kaya nanginginig is bumubomba ng husto compressor at tumataas ng husto ung pressure dahil ying refrigerant sa condenser side sobrang taas na.
Servo? ?? E di dapat kung ireredondo mo lalamig aircon. So kung hindi pa din lumalamig ac malamanag hindi servo tama nyan. Pero ok din ipalinis yun para efficient engine
May 4th, 2013 10:57 PM #6
- Jun 2005
- 3,774
May 5th, 2013 12:12 AM #7
May 5th, 2013 01:12 PM #8
May 5th, 2013 03:11 PM #9
- Aug 2010
- 86
May 6th, 2013 11:40 AM #10Sir brainmafia_310,
Ask ko lang po advice nyo..sign po ba ng compressor problem pag nasa correct level ng freon (low pressure) ay parang naghe-hesitate sya, then yung engine nag-rarough idling na sya? surplus kasi yung compressor na pinalitan 1 year ago. Pag off yung aircon, ok naman yung idling..
Thanks po and more power.
Regards,
Tesla Philippines
