Results 1 to 8 of 8
    ride is 1995 toyota corolla gli (4afe ae101), just wanna ask kung san makikita yung control nung nagtritrigger sa idle-up pag engage ng compressor? negative kasi yung nagtritrigger e, gusto ko malocate kung san banda/makikita yung control nito. please help guys. thanks
    Feb 2009
    Quote Originally Posted by bogcbogs View Post
    the idle up for a/c is the a/c request switch as an input to the pcm which enables the idle air control. if the a/c does not engage due to low or too high of the refrigerant pressure, the clutch does not engage and the idle up solenoid or idle air control will likewise fail to respond
    so sir, san po galing yung negative na nagtritrigger ng idle up?
    the ecm will supply the ground
    Quote Originally Posted by t2erns View Post
    sir, ano po yung ecm? san po sya located?
    ecm engine control module (now called pcm powertrain control module)
    ah ok, thanks po
    sir, san po makikita yung ecm? san banda nakalagay?
trigger
