Results 1 to 6 of 6
June 25th, 2013 02:52 PM #1
Hello sa lahat,
paano po linisin or tangalin ang evaporator ng TOYOTA INNOVA,
Spray ko na ng lysol sa AIR BLOWER INTAKE, after 1 or 2 days bumabalik ang smell, at ang baho,
sino meron idea or experience paano linisin ang DRAIN / EVAPORATOR / INTAKE ng toyota innova 2011.
salamat
June 25th, 2013 03:27 PM #2
amoy suka (vinegar)?
don't use lysol.... pag nakulob, lalong babaho.
try to use the vent out settings muna and observe... dahil those kind of smell are fungus growth..
try din muna to change your cabin filter.
yung AC internals are only cleaned if extreme na yung reasons.
and you need to dismantle the entire cabin/dashboard to reach this, imho.
- Jul 2012
- 62
June 26th, 2013 12:52 PM #3
I've tried this with our innova and yes it did eliminated the bad odor but there's another problem not directly connected sa mabahong air con.
Minsan ang innova namin malakas ang aircon kapag ka mga 1 hour mo palang gamit pero pag tagal sorbang hina na ng buga ng aircon parang todo na ang fans pero sobrang hina ng labas ng hangin. rinig mo ung lakas pero ang hina ng haning mahina pa sa 1. parang may pinupuntahang iba ung hangin at hindi sa vents.
What could be the problem kaya? May problem sa radiator pero weird naman kung dahil dun.. at napalitan na namin ung ng aftermarket na evercool at wala na namang naging problema.
anu pa kayang problema ng aircon ng innova namin..
- Aug 2005
- 553
June 27th, 2013 03:35 PM #4What you are encountering is due to the fact that your A/C evaporator is made of aluminum and not bacticidal like copper condensers of old. In cases wherein the air drawn into the cooling coil has either food, or anything organic, once it gets deposited on the surface, bacteria thrives on it.
Open your A/C, spray Lysol generously underneath the dash on both sides. And I mean generously. If the contamination is only on the surface, this will get rid of the smell.
Watch your eyes and don't breathe in the exhaust on the vents while spraying.
If the contamination is substantial you will need to bring the thing down and clean it. Wouldn't hurt to do the same on fabric surfaces as well.
The quick solution there has nothing to do with the radiator. ayliasabelle, some subtlety please, you're making that company look less credible with every post.
- Sep 2011
- 22
July 1st, 2013 01:00 PM #5sir, Linson,
kung malapit po kayo sa makati hanapin nyo po ang RDC car aircon repair shop, sa kamagong st corner anubing st. makati
or text nyo po c Ronald # 0921-8059258
Tesla Philippines
