Re: Radiator / Overheating Problem
Quote:
Originally Posted by
mina_nuka
thanks sa link bro
ninjababez
your old pump still looks practically new.
it must be those new coolant formulations.
the trick now is, how to store that new pump, so that by the time you need one years from now, you still remember where you tucked it....
you know.. the old "i know i have one somewhere here... now where did i put it... that was back when hindi pa ako grandfather...?" heh heh.
or, go back to the store and exchange it for something else.
dr. d
installed na yun bago bro. meron naman akong old stash closet, minsan kasi may tsamba na may kailangan or need ko ulit. pwede ko rin post sa o l x hehehe
We won't really know the condition of the water pump motor ... Until it conks out ... So replacing it early is a good thing to do ...
mga bros, any idea alin mas malakas dito sa dalawa?
any ideas what the numbers mean?
https://uploads.tapatalk-cdn.com/201...fbc7ded942.jpghttps://uploads.tapatalk-cdn.com/201...c98384efb1.jpg
dr. d
looks are ok, but how about the bearings? these can sieze up over time.
ninjababez
Tingin ko pareho lang eh. Piliin mo na lang mas mukhang bago. That is if both are legit.
dr. d
typical po ba mga size ng waterpump ng sasakyan?
ninjababez
If it fits and mounts directly to the fan shroud it should be okay. Try running it direct to the battery and measure the current draw and compare. If the current draw is higher you might need to change the wire size to carry the load without overheating the circuit
