Results 1 to 10 of 287
Threaded View
March 31st, 2017 08:52 PM #9
What is your reference level for the coolant fluid?
The coolant fluid container is marked F and L
If your reference is above F then its normal because F should be maximum level of the fluid. As in the proper level should be F and below for the coolant fluid, while F and above should be air
Why that should be the case? Build up in heat result in greater pressure which push that fluid level above the F mark. If you filled the the coolant container up to the brim, then that will be indeed the case, there will always be reduction in fluid level, as long as its not below L mark, then the coolant level should be ok
If you carefully inspect the coolant container, there is an overspill hole on top. That takes care of excess fluid upon pressure build up, it discharge excess coolant fluid due to pressure expansion
The best practice in filling up coolant is up to F mark level only
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; March 31st, 2017 at 08:59 PM.
