Page 6 of 6 FirstFirst ... 23456
Results 51 to 58 of 58
    Jul 2003
    #51
    what's the best available coolant in the market? Pansin ko lang po kasi malakas magputik sa reservoir yun coolant ng Petron. ethylene glycol naman po lahat sila, di ba? Lahat po ba sila ganito?
    #52
    Baka may sludge na sa loob ng mga water jackets and other cooling system parts mo.
    Gusto ko yung sa Caltex kasi long life siya.
    #53
    I agree with Sir Otep. I think the best coolant available is the Caltex Extended Life Coolant since based from it's label ay di mo kailangang palitan ng up to 5 years or 200,000 kms. It means maintenance savings. Pero twice ang price niya compared to the regular coolants. I had it placed in my Strada.
    Jul 2003
    #54
    sir otep ; oo nga eh. 20T kms pa lang yun xwind ko. di naman tumataas yun temp gauge kaya lang ever since petron coolant na yun ginagamit ko. try ko caltex coolant. kaya lang would you recommend na paflush ko muna o pwede na diretso lipat na?
    #55
    Sir Scanner,
    Drain the coolant from your radiator as I described and fill it with the recommended 50:50 coolant:water ratio of your desired coolant. Maganda na din po ang Petron Coolant. You don't need to change it right now kung wala naman pong problema. I suggest you do it at your manufacturer's recommended schedule wich is usually 40k or 2 years. Goodluck.
    Jul 2003
    #56
    Thanks po, sir roydok.
    #57
    #58
    saan ok magpa-lavramon sa las pinas/alabang area? and how much kaya?
radiator flushing/cooling system questions
