Results 1 to 8 of 8
- Jan 2004
- 119
April 11th, 2008 05:03 PM #1Good day tsikot peeps! Tanong ko lang kung anong problem nang aircon ko. During tanghaling tapat eh minsan di lumalamig ang aircon ko at napapansin ko bubukas lang ang mga fans at tataas ang idling pero di mag eengage ang compressor kaya walang lamig. bad trip nga kasi nangyayari yon pag tanghaling tapat.
What do you think is the problem? Thanks
PS. Any good aircon shop here in manila?
April 11th, 2008 07:12 PM #2
maraming maaaring maging cause kaya hindi magengage ang compressor,mahina ang aux fan kaya naghigh temp nag disengage ang compressor. barado ang expansion valve kaya naghigh temp nag disengage ang compressor, madumi na evaporator kaya mahina ang lamig, pa check mo nalang sa suking aircon shop para sigurado at mapalitan na ang mga parts na sira na, expansion valve, filter, aux fan, kung kailangan pa linis na rin ang evaporator.
- Jan 2004
- 119
April 11th, 2008 07:40 PM #3ahhhh i see. kasi napapansin ko nangyayari yun pag tanghaling tapat. and bukas ang lahat nang aux fans ko, mataas ang idling pero ayaw magengage nang compressor
- Feb 2008
- 325
April 12th, 2008 07:30 AM #4pa-check mo lang yung cooling system mo. baka mahina na buga ng hangin ng mga fan mo. check mo rin kung nagbabawas ng tubig yung radiator mo. better bring your car sa reputable shop for check-up.
- Jan 2004
- 119
April 12th, 2008 09:10 AM #5just had my radiator checked for leaks and ok naman lahat. will ask my mechanic about the aux fans.
- Jan 2008
- 4,726
April 12th, 2008 12:29 PM #6well you may also opt to check your compressor clutch coil if all items above is checked OK.. it will not engage if the magnetic coil clutch is already busted..also possible you have a loose wiring connection to the compressor clutch
Tsikot Member Rank 4
- 2,719
April 12th, 2008 12:53 PM #7maraming aircon shops libre check-up ... they will connect thier pressure gauge/s to determine if your compressor is doing its job properly and/or the system lacks freon
- Jan 2004
- 119
Tesla Philippines
