Results 1 to 10 of 16
October 5th, 2007 09:33 PM #1
i need help on this. nawawala lamig ng aircon ko, then napansin ko tila umuusok then later on, pinapawisan ang aircon outlet ko. somebody suggested palinis, ok na daw. however, matapos malinisan, ganon pa rin. advise ng technician, palitan ang thermostat. thermostat ba talaga dapat palitan dito?
October 5th, 2007 09:36 PM #2
may "click" intervals pa ba?? ganyan din ata yung akin dati kaso nauuna ung usok na puti, after that wala na yung lamig pag inangat yung hood ayun, nagyeyelo na yung daanan ng air, ang logic.. nababarahan na yung daanan ng air...
October 6th, 2007 04:42 AM #3
General Cleaning ba nawaga sa aircon mo? na replace iyun aircon filter?
October 6th, 2007 05:52 AM #4
yup, general cleaning. all filters had been changed. when the technician opened the evaporator "case", it was covered by ice. pero ganon parin, nawawala ang lamig.
October 6th, 2007 07:10 PM #5
di kaya ref yan at di aircon? seriously, it could also be your expansion valve.
October 6th, 2007 08:55 PM #7
Check if the Evaporator filters are clogged. Maybe the Evaporators itself are clogged.
Check also the function of the blower. If the blower is weak, it will not be able to let enough air pass through the evaporator...hence the evaporator's temperature will drop until it reaches the freezing point.
I experienced this before in my old old tsikot..what I normally do is I just turn the A/C off...let the blower run...the ice will melt in a few minutes..then turn the A/C on again. This is only a quick fix until you are able to find time to properly clean your system.
October 7th, 2007 02:28 AM #8
isolate mo muna yung problem ng theremostat. try mo adjust to a lower setting. pag hindi nag automatic, theremostat nga.
ganyan din problem ng a/c ko dati. climate control sya. pag long driving nagyeyelo. naayos naman after general cleaning. (palit expansion valve, drier)
October 7th, 2007 07:07 AM #9
brods, thanks for your suggestions. yup, thats what im doing now, manually turning it on and off and it works for now. ill check the blower too. it could be the reason for this. i think i need to have this car for a check up again in another aircon repair shop. hassle masyado. im hesitant to change the thermostat bcoz it may be not the problem. medyo may mahal ang sa xto. tnx.
October 7th, 2007 07:11 AM #10
barado po kung ganyan.
kelangan jan system reprocess, para matanggal yung bara sa mga tubes
pati condenser at evap need i flush
Tesla Philippines
