Results 1 to 10 of 17
- Sep 2005
- 8
May 16th, 2007 10:59 PM #1mga sir, tulong lang po.
Sira na ba kaagad yung cylinder head gastket if may parang white na bula (maliliit) or suds pag binuksan yung radiator cap. Nawawala naman minsan.
Palit na ba agad ng gasket and resurface ng head or papa bleed ko lang?
Pero wala namang halo ng oil yung reservoir and radiator ko. Pure water pa din (wala akong coolant). AFAIK, pag may oil na yung radiator or reservoir ko, dun lang sira yung gasket. Tama ba?
Tumataas temp ako minsan pero bumababa siya after a while. Walang tulo or bawas sa radiator or reservoir. Feeling ko yung thermoswtich ang problem hindi blown gasket. Tama ba?
kotse ko ay civic ek97
Thanks
- Sep 2005
- 8
May 16th, 2007 11:39 PM #3Ayos pa yung thermostat eh...bumubukas pa sa boiling water. Yng small "suds" or white bubbles, cause ba ng blown gasket? wala namang oil sa radiator. hindi rin nagiba yung color ng oil ko nor its level. kasi ayoko naman palit and resurface ng head kung hindi naman sira.
Tsikot Member Rank 4
- 2,719
May 17th, 2007 12:00 AM #4check mo radiator fan motor, baka mahina na ikot nya or minsan hindi iikot kasi worn out na carbon brush or bearing ... hindi yata nabubuksan ang motor, bago or surplus unit lang ang remedyo ... nangyari na rin ito sa civic esi ko dati
- Nov 2006
- 103
May 17th, 2007 03:37 AM #5kung fan ang problem mo...baka pde papalitan lang ng carbon brush..sa accord ko kasi pinapalitan ko lang..inabot lang ng 300 labor n materials na yun
- Sep 2005
- 8
May 17th, 2007 08:28 AM #7
May 17th, 2007 09:06 AM #9
last resort mo ang top overhaul.. ganyan ginawa ko, kaya lang gastos, atleast naayos lahat...
sign ng needing top overhaul is that, at idle, tumataas ung tubig ng unti-unti, pag rev mo, lumalakas....
pero pag at idle, violently na ang tapon ng tubig sa radiator cap hose, -->top overhaul na yan, kahit di pa naghalo ang tubig at langis!
May 17th, 2007 09:08 AM #10
if the water jumps out the radiator opening when the engine is on, it is a sign of blown head gasket.
Tesla Philippines
