Results 1 to 10 of 25
May 16th, 2014 02:54 PM #1
Hi guys,
Ask ko lang if this is just a thermoswitch issue. Nagpalit kasi ako ng thermoswitch(Tama brand) last 2 weeks. nagswitch on ung radiator fan (w/o aircon) * 96C pero last night nagoverheat signal ung vios ko w/ aircon * blower speed 1 tapos bigla din nawala. inopen ko ung phone ko to check sa torque pro ung temp. nagulat ako 94C lang so pinatay ko aircon drive for a while nag 96C then baba ng 93C tapos naulit lumabas ung overheat signal pero wala naman nagiba sa takbo. I checked the coolant and reservoir. di naman nagbawas.
Saka issue ko din is pag sa tanghali ang lamig ng aircon(blower # 3)and the coolant temp is ranging lang from 86C-92C pero sa gabi medyo di malamig ang aircon and temp is umaabot ng 96C with aircon on * blower # 2. same aircon thermostat din * 3oclock.
Any thoughts kung ano sira?
May 16th, 2014 04:00 PM #2
I've reached til 99 sa obd/torque pero never pa nag light up yung hi-temp warning. Baka di factory range yung nalagay mong thermo switch. Same reading tayo 86-95 pag naka ac.
- Jun 2005
- 3,774
May 16th, 2014 04:32 PM #3ganyan din naman heag range mg mga vios samin pero di umilaw overheat light. gen 1,2,3 lahat ganun
Sent from my Thrill 430x using Tapatalk 2
May 16th, 2014 04:32 PM #4
May 16th, 2014 04:36 PM #5
- Jun 2005
- 3,774
May 16th, 2014 05:07 PM #6baka generic sensor nalagay mo for other toyota vehicles na overheat na at 96deg.
sa vios kasi normal temp yan eh. let us know kung umayos after mo iswap with the old sensor
May 16th, 2014 05:57 PM #7
Okay sir iDIY ko bukas. balitaan ko po kayo. tuwing gabi lang naman umiinit makina ko. thanks sa replies!
May 17th, 2014 12:40 AM #8
UPDATE: I tried to replicate the scenario kanina. This time nagblink ang overheat signal * 96C twice 'pag naka aircon lang. twice mag blink tapos pagbaba ng temp nawala din ung overheat signal. I tried din walang aircon but hindi lumabas ung overheat signal. connected kaya ito sa aircon?
May 17th, 2014 12:06 PM #9
Double Check if yung thermoswitch na pinakabit mo is yung para talaga sa vios mo,
if it is, you could try replace your cooling system's coolant with a fresh one,
and check also your cooling systems thermostat, might be ndi na nagbubukas sa tamang
heat range nya.
medyo alanganin gamitin yung kotse madalas magblink ang overheat lamp.
May 17th, 2014 07:14 PM #10
UPDATE : Pinalavramon ko kanina sa romy's naka 3 banlaw bago luminis ung buong cooling system. nalinis din ung radiator and condenser. grabe dumi. wix coolant ang nilagay at tinanggal din ang thermostat.
bukas iDIY ko palit ng thermoswitch back to OEM.
Question : Sa mga vios ba pag nirev ang engine tatalsik ba ung coolant nito pag walang radiator cap? sorry noob
