Results 1 to 4 of 4
December 12th, 2009 02:06 AM #1
Hi guys!
I have a problem on my a/c switch nga ba?
Pag naka on ang a/c switch ko minsan ayaw gumana ng green na light malapit sa a/c button and at the same time hindi malamig. Then pag tumakbo na ako mga after 3-25 mins. iilaw na ung light sa a/c at the same time lalamig na ang hangin.
Ano po kaya problema nito? Do you ever encounter this same problem?
Kelangan ko na po ba patingnan baka po kasi lumala pa eh?
December 12th, 2009 03:04 AM #2
It's a common problem of the Optra pag nakabilad yung sasakyan then pag-andar mo ng makina eh i-oon mo agad.
It's not really a problem, yun lang you'd really have to give it enough time for the A/C to function (hence after 3-5 minutes pa bago umilaw uli).
What I did then was apply pressure on the thermostat switch pasagad. Makes it work sooner if you really have to. HTH. =)
December 12th, 2009 12:45 PM #3
ah ok po, ganun pala talaga ang optra. buti na lang at normal yun kasi ang mahal ng switch assembly daw ng optra 8k daw. sundin ko n lang payo mo.hehehe thanks
- Dec 2009
- 3
January 3rd, 2010 09:15 PM #4Ganyan talaga switch ng aircon ng optra "parang defective". They (Chevy PT branch) just replaced my aircon switch kasi yun daw ang problema at hindi nag automatic shut off ang compressor. 8k ang switch tapos nung pinalitan, hindi pa rin na solve ang problem ng aircon ko....Ayaw naman nila pumayag na ibalik ang switch kasi nakabit na raw. Ang switch pa na nakabit nila parang nag eestuck-up...kailangan pa pindutin ng 3-5 times bago mag-on or off ang ilaw na green sa aircon...Kung gusto mo may spare ako na aircon switch na wala na gamit, mas maganda pa sa nakakabit na switch sa optra ko ngayon...
Tesla Philippines
