Results 1 to 6 of 6
- Jul 2012
- 22
July 27th, 2012 12:08 PM #1normal lang po b na parang naglalangis ung rubber hose ng a/c coming from compressor going to condenser, ito yata ung high pressure coz H nakalagay sa aluminum fitting? pansin ko po na khit punasan ko e oily pa rin after using the car. is this ok or sign of leakage but a/c is cold
July 27th, 2012 12:33 PM #2
It's a sign that the oil inside your ac system is leaking out eventually the coldness of your ac system will start to degrade. Better have it replaced and make sure your system is properly vacuumed and flushed.
July 27th, 2012 12:38 PM #3
tama po si sir diesel... may leak na po yung hose nyo... check nyo yung hose at fittings.... lagyan nyo lang ng sabon makikita nyo na kung may leak...
- Jul 2012
- 22
July 27th, 2012 02:56 PM #4just checked w/ soap the hose and fittings, wala nmng leak, pansin ko lang na may slight sugat ung hose na nagooily, may oil or lubricant po ba ang hoses ng a/c w/c serves as insulation? baka kc ung inside ng hose ang nagleleak ng oil
July 27th, 2012 03:47 PM #5
- Jul 2012
- 22
