Results 21 to 29 of 29
- Sep 2008
- 699
April 12th, 2015 01:11 PM #21
- Apr 2015
- 140
April 12th, 2015 06:36 PM #22t, you'll notice excessive amount of play dun sa part na may spring. Usually corroded na din yung spring. If that happens, the cap would not be able to hold pressure anymore, resulting to overflow ng coolant/water sa reservoir. Anyway rad caps are quite cheap. You can get a federal mogul cap at around 120php or less.
- Apr 2015
- 140
April 12th, 2015 06:39 PM #23Another tell-tale sign of blown head gasket is a greasy feel sa rubber seals ng rad cap mo. Youll notice na parang may grasa sa paligid ng rad cap. Thats engine oil seeping thru the blown head gasket
- Oct 2009
- 2,271
April 13th, 2015 02:53 PM #24abay kaya yan ung sa akin nga trinavel kopa from manila to nueva ecija blow na at singaw ung gasket.
kung gasket lang din papalitan mas maganda pa reface mo na ung head.para pumantay.tulad sa akin ganyan din problem nagpalit kami ng gasket lang after 3 day baklas ulit kami. kaya reface na ginawa.saka bili ulit bago gasket,
April 13th, 2015 03:03 PM #25
it's SOP to check cylinder for warping once na nagbaklas ka. since nag overheat na yung oto ni TS...chances are warped na iyon.
- Oct 2009
- 2,271
April 13th, 2015 03:20 PM #26mas maganda na nga pa reface na for sure ako 1.2k ang binayad ko sa machine shop baka mas mura dito sa manila.baka nga nasa 1k lang.
tutal naka baklas na mag palit kana din ng valve seal..
- Jan 2015
- 468
- Apr 2015
- 6
- Mar 2014
- 901
June 16th, 2015 12:40 AM #29
