Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Dec 2009
    Naka hanap nako sir ng shop na marunong sa engine coolant drian plug. Tinanggal muna nila yung termostat para matanggal yung drain plug sa engine block. Surprisingly walang coolant na tumapon sa makina. Nagtataka sila kung bakit hindi nag ooverheat yung sasakyan. After that pina flush ko na tubig then pinadaan ko na yung coolant mismo papunta sa makina. 3L na coolant bago napuno. Then sa radiator 3L din puno na. Dapat 8L bago mapuno based sa manual pero 6L lang puno na. Bat kaya??
    Jun 2006
    That's interesting. Hopefully you find out why before it's too late. Haven't changed coolant myself before so no idea. Baka may bara. Have u tried running the engine? Baka may hangin (2L worth LOL).
    Dec 2009
    Chineck nila wala namang bara saka nung napuno na yung radiator binirit din nila makina para daw bumaba yung coolant. Halos 500ML din yung nalagay after ibirit. Sa ngayon ooberbahan ko nalang kung tataas yung temperature. Babaunin ko nalang lagi yung sobrang coolant. Nung pauwi ako galing talyer around 5KM yung layo stable naman yung temperature
    Apr 2013
    D
    Quote Originally Posted by radz15 View Post
    Naka hanap nako sir ng shop na marunong sa engine coolant drian plug. Tinanggal muna nila yung termostat para matanggal yung drain plug sa engine block. Surprisingly walang coolant na tumapon sa makina. Nagtataka sila kung bakit hindi nag ooverheat yung sasakyan. After that pina flush ko na tubig then pinadaan ko na yung coolant mismo papunta sa makina. 3L na coolant bago napuno. Then sa mradiator 3L din puno na. Dapat 8L bago mapuno based sa manual pero 6L lang puno na. Bat kaya??
    San yun shop bro?
    D
    San yun shop bro?
    Dec 2009
    Sa sucat road Parañaque. D & R name ng shop near SM Lopez
    Air pockets. You have to run the engine so that the pump will circulate the coolant and you have to top it off.
    Dec 2009
    Yup. Rinev na ng matagal but still 6L nagamit. Wala namang bara
Need help!  Palit ng coolant
