Results 1 to 9 of 9
November 28th, 2012 03:54 PM #1
may nakapg try na ba ng MicroMagic Coolant? mura siya nasa 99php per 500ml. any feedbacks? thanks!
- Aug 2005
- 553
November 28th, 2012 07:39 PM #2
November 28th, 2012 09:14 PM #3
ang alam ko pareho nung binibenta sa blade na coolant, yung blade na ang brand.pero same bottle. and plagiarized yung maka naka sulat sa likod ng bottle, word for word pareho nang sa prestone coolant, except pinalitan lang nila ng MicroMagic yung word na prestone. manufactured by DUB GLOBAL, nagoya japan. yan ang nasa label nya sa likod.
November 28th, 2012 09:24 PM #4
Use OEM, even if it costs slightly more. Minsan ka lang naman magpalit ng coolant.
A coolant's job is not as simple as it may seem. Much like what the engine oil does, the coolant also have the job of inhibiting chemical reactions and at the same time, lubricate the water pump and protect the rubber seals. Using the wrong coolant may have both short and long term effects.
- Aug 2005
- 553
November 28th, 2012 10:33 PM #5Could be a private label like Blade.
Thing is, 500ml of water is a few centavos. 250ml of Glycol costs more than 90 bucks in retail. Spider sense tingling.
- Aug 2005
- 553
November 28th, 2012 10:34 PM #6
November 28th, 2012 10:40 PM #7
I use only OEM coolant. I don't want to gamble on other brands like Micro Magic. Baka iba ung ratio ng chemicals or formulation sa loob.
November 28th, 2012 10:41 PM #8
Check your vehicle requirements. For units that call for ethylene glycol base coolants, we use zic super A pre mixed coolant. 880 per four liters
For Toyotas that use long life coolant, thats the only fluid we use. Or in an emergency, distilled drinking water.
- Aug 2005
- 553
November 28th, 2012 11:59 PM #9These aftermarket things are mostly diluted concentrates.
If and ONLY IF, you find yourself in the middle of nowhere and the only available water is dirty, use a piece of cloth to filter the water.
Then flush your system the first chance you get and replace your coolant.
I've seen enough people that are too hardheaded insisting that water alone is fine.Last edited by EVO-V; November 29th, 2012 at 12:04 AM.
