Results 11 to 20 of 23
- Jan 2012
- 10
January 10th, 2012 05:51 PM #11Ah... cge sir I'll have that checked too this weekend. I'm trying to list down the things I need checked. Mahirap na at baka maloko nanaman ako. So so far I have 2 things na:
1. Electronic Thermostat
2. Expansion Valve
Thanks guys for feedbacks! My wife is going to give birth this month so any unnecessary gastos sa fix this weekend will be a big help for us.
- Jan 2012
- 10
- Jan 2008
- 4,726
January 10th, 2012 06:14 PM #15
I think you can only buy electronic thermostat sa casa...ok naman manual thermostat dahil a very cheap replacement but just make sure na walang problema sa system
- Jan 2012
- 10
January 10th, 2012 06:27 PM #16Sir, yung electronic thermostat ba nakakabit yung sinasabi nyo?
Ok sir. Naka manual T-stat na siya ngayun. So, yung erratic na pag off yung ipapa ayus ko na lang and also yung ibang parts na din like yung drier and valve.
Thanks sa mga nag reply, you guys rock!
January 11th, 2012 01:11 AM #17
Forget the workarounds and have it fixed back to OEM spec. That means, remove all previously-installed non-factory parts and have the ECU checked if it's actually defective or not.... Once and for all. Do this before you decide to overhaul the whole A/C system. It's icing, you said, so chances are there's nothing wrong with the actual A/C parts but just certain components that controls its on/off cycle.
The intermittent lack of power may be attributed to the hack. In a fully-functional car with the ECU in control, it knows exactly when the compressor is engaged and it would in turn increase power to the engine to compensate for the drag. With the ECU bypassed, your operating the compressor independent of the ECU's decision, so it may not be compensating for the power loss when the analog thermostat commands the compressor to engage.
January 11th, 2012 09:22 AM #18
tama, ibalik sa dating set-up ang ac mo (esp kung ATC). have it checked by qualified tech or sa casa. the ac system is controlled by computer, the computer must know that you want the ac on para ma adjust nya and engine speed mo before turning on the compressor. when operating at wot (wide open throttle. the computer will automatically cut the compressor operations), also pag mataas head pressure i cut din ng computer ang ac. yung icing ay madaming pwedeng maging cause; pwede ding sira ang low pressure cut-off switch, undercharge, madumi,wiring papuntang ac relay, etc.
- Jan 2008
- 4,726
January 11th, 2012 09:48 AM #19kung may separate switch yan A/C mo yun muna pa check mo... secondary switch lang kasi yung thermostat... as i have said sa setup ng kotse ko.. kahit naka manual t-stat ako eh controlled pa din ng ECU yung A/C... although i have a separate switch for the A/C the relay for the compressor is still controlled by the ECU so pag na sense nung ECU na nahihirapan yung engine ko momentarily switch-off nya yung A/C to allow the engine build up power...
also have the pressure switch (located sa drier or near the drier) checked... nag ice yan A/C mo kasi hindi nag automatic cut off yung compressor plus madumi na yung cooling coil mo kaya nag stay yung tubig in between the fins na nag ice kapag sobra na lamig... actually pag nag ice yan mawawala ang lamig sa air vents kasi na block nung ice yung daanan ng hangin
January 11th, 2012 02:37 PM #20
assuming your refrigerant quantity and pressure are within specs, check your vent registers for correct airflow/delivery, usually, this is done with a manometer (comparing your airflow with a known good car of the same make and model). if the airflow is low, the result is freezing of the evaporator core and of course further reduces the airflow across it. this climate control system (your computer controlled airconditioning) uses a pressure transducer installed in the low pressure side plumbing. it has three wires: PINK-low reference, LIGHT BLUE- 5 volt reference voltage, DARK GREEN (DOHC)-pressure signal or PURPLE(SOHC)- pressure signal. have this transducer checked first. this climate control is also sensitive to antifreeze/coolant amount in the system, if it is low, the climate control operates erratically too
Tesla Philippines
