Page 1 of 2 12 LastLast
Results 1 to 10 of 43
    Aug 2021
    Quote Originally Posted by sniper261985 View Post
    Thank you sir Mark sa additional input nyo sir and allowing me po na makapag-post sa thread mo. Regarding sa aircon fan and radiator fan sir sabay sila namamatay then sumisindi ulit, dko pa gaano namonitor ung fan ng aircon bago lang po kasi ung kotse sakin pero ung radiator fan confirmed kona na namamatay then sisindi ulit kapag naka-on ang aircon ko sir. Ang inaalala ko lang sir since iikot lang sila kapag naka-sindi ang aircon pano kaya kapag hindi po ako nag-aircon, dahil walang fan baka mag-overheat makina. Tulong naman po sa mga expert dyan. Ano po ang normal behavior dapat ng aircon and radiator fan? Thanks
    ganyan din sakin sir ano po gagawin po pagganyan normal bayon sir yong sasakyan sir pinz chev 1.5 2015 pa po puede pong patulong po
    from what i remember,
    in cars that have their engines positioned laterally,
    with the aircon off, the engine's thermostat will turn the radiator aux fan on or off, depending on engine temp.
    with the aircon compressor running, the aux fans for radiator and for aircon will both run.
    Sep 2005
    Yesterday i saw the "overheat" indicator light up in my 2015 Honda City's dashboard. So I immediately pulled over and checked under the hood. Upon my own observation, my radiator & reservoir had enough water. Radiator aux fan was working -- it turned on automatically when it reaches a certain temp. However, I noticed that when I turn on the AC, the aircon aux fan does not turn on. The aircon aux fan should turn on immediately when I turn on the AC, correct or does it only turn on when it reaches a certain temp? Anyway, it did not turn on at all even with the AC turned on for 10mins -- as such, i suspect this was the cause of the overheating.
    Is this normal? Should the AC aux fan immediately turn on simultaneously with turning on the AC or does it have to hit a certain temperature before it turns on? Any idea how much to replace AC aux fan motor and the best place to have this replaced na hindi sa Casa???
    Thanks in advance mga ka-City for your advise on my problem.
    Jan 2009
    Based on my experience with Hondas, both fans should run at full speed whenever the A/C compressor is running, no matter what the engine temp is.
    with the aircon control set to maximum cool,
    that aircon aux fan should rotate, regardless of what the radiator aux fan is doing.
    bring it to the aircon shop.
    the aux fans should be easy to troubleshoot.
    bypassing the thermostat/relay should turn it on.
    This sabay talaga dapat pag bukas ang a/c
    Jan 2009
    For something as critical as aux fans, they should already have a locked-rotor signal in this day and age. We take that for granted in PC CPU and case fans for well over 20 years. Cars with aux fans has been around much, much longer with the potential for engine damage much higher.
    It can either report back to the ECU the RPM of the aux fans and compare it with acceptable values, OR at the least, detect if the fan rotor isn't turning when it should. So when the fan(s) don't achieve a certain speed or has stopped turning, it could trigger a DTC.
    my overheating sentra was one such. the problem had been going on for some months, and i couldn't see the problem.
    it was solved when an old-timer mechanic showed me the way.
    "umi-ikot naman, ah! malakas pa nga, oh. tignan nyo."
    "boss, bili ka nang bagong aux fan, and i will show you just how strong it should be."
    he was right.
    by my estimate, my old fan was rotating at about half of what it should be. it would have passed muster, to the in-experienced like me.
    another time,
    i was losing coolant, and i couldn't see from where.
    finally, i (or rather, my mekaniko) saw it.
    it was a leaking 4 inch long black rubber hose, near the intake manifold. i didn't even know there was a hose there. i couldn't see it because of the jumble of electrical wiring above it.
    Sep 2005
    Quote Originally Posted by runner10 View Post
    Update:
    Turns out both my fans are broken and both need to be replaced.
    Aircon shop quoted my 4,000 pesos for 1 Mitsuba aux fan motor with labor na.
    So 8,000 pesos for both. Reasonable or mahal?
    TIA guys.
    Jan 2008
    Update:
    TIA guys.
    MAHAL!!! brand new ba yan? or surplus?
How should the aircon fan and radiator fan work?
