Results 1 to 10 of 10
- Aug 2010
- 86
August 24th, 2013 12:04 AM #1Hello Sirs,
Ask ko lang, paano nyo natatanggal rust sa radiator nyo? OEM pa radiator ko pero may trace na ng rust sa cover pati sa visible part sa loob ng radiator. Honda City 2004 po ride.
Salamat ng marami.
- Aug 2010
- 86
August 24th, 2013 10:27 AM #3Ok thanks. Nung nakuha ko yung unit, konti pa lang, ngayon medyo dumadami kayo bago ko sana palitan ng coolant, maalis muna yung mga rusts.
- Oct 2009
- 2,271
August 24th, 2013 03:10 PM #4may nabibili ini spray radiator cleaner tanong ka sa blade or sa mga auto supply..
- Aug 2005
- 553
August 24th, 2013 11:32 PM #5If its just a flush all you need are those radiator flushes.
If you're trying to get rid of rust, meaning solid particle debris, you will need to attach a mesh filter to your radiator inlet, run it for a a few days, then clean it out. Repeat until you're satisfied.
This is applicable for older engines.
If you're trying to get rid of rust as a whole, you'll need to be more diligent in your coolant replacement or use a waterless coolant altogether.
Do take care of how you dispose of your used coolant.
- Jul 2010
- 570
- Sep 2013
- 153
October 1st, 2013 01:12 PM #7
- Aug 2005
- 553
October 5th, 2013 09:55 AM #8No, there are waterless coolants that have a specific formulation to be used without water.
If you use pure ordinary coolant, you will have only 45-55% of the conductivity of water.
- Aug 2005
- 553
October 6th, 2013 08:50 AM #9I would be more keen on preventing rust in the first place.
http://tsikot.com/forums/aircon-temp...ml#post2211758
- Jul 2012
- 62
October 7th, 2013 11:17 AM #10Well, you can follow the steps provided in this thread or you can opt for a replacement.
check Evercool Radiators
Tesla Philippines
