Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
    Feb 2012
    #21
    Quote Originally Posted by Alfrance05 View Post
    At around what time of the day nag check sa pressure readings? Sa akin kasi is at noontime, pinaandar namin ng atleast 30min to 1 hour then check the pressure readings. Before kasi when buhusan ng tubig, lalamig yun ac then after a while balik sa dati, then sabi nya na replace condenser and aux fan, after nun ok na lahat..
    Mga 4pm na ata yun sir
    May 2012
    #22
    Still original yun ac sa likod.. Umabot naman.. Pero sa tanghali full blast sa likod pra aabot..
    May 2012
    #23
    Saw the pic already.. Saan banda yun buga sa aux fan mo?
    May 2012
    #24
    Click image for larger version.
Name:	ImageUploadedByTsikot Forums1437879264.852999.jpg
    Ito yung ginamit ko. It fits exaclty sa condenser. I chose this kasi mas malakas and quiet. Yun buga is downward, towards the road.
    Btw, ilang condenser ginamit mo?
    Feb 2012
    #25
    Pababa ng kalsada sir
    Feb 2012
    #26
    Dalawang condenser sir parehas ang size
    Feb 2012
    #27
    Yung sakin dati di kaya nung dipa ako naka Yokohama ngaun medyo OK na basta mga 10 LNG karga sa likod
    May 2012
    #28
    As far as the inage shows, medyo maliit yun aux fan sa right side. Ilang fans gamit sa condenser sa gitna?
    May 2012
    #29
Name:	ImageUploadedByTsikot Forums1437880275.225128.jpg
    No additional fans sa loob. Original lahat. Although i had to seal every ducting sa rear ac since over time may leaks evident sa moisture sa pader ng van even on hot days.
    Original man o converted, lalamig parin yan. The usual culprit kasi if dahan-dahang mawawala yung lamig on hot days and given you have the right amount of freon is yun condenser and aux fan and the setting of the expansion valves.
    Feb 2012
    #30
    Ung sa gitna sir isa lang gamit yung parang pang starex lang
Hindi nag automatic compressor
