Results 1 to 10 of 15
January 22nd, 2007 06:18 PM #1
when my aircon is in fresh air mode, walang hangin na lumalabas sa blower. pero pag recirculate, meron. ano kaya problem? halos hindi ko naman kasi ginagamit yung fresh air mode, pero siempre it might be a sign of a problem about to start.
January 23rd, 2007 07:26 AM #2
are you the first/orig owner? if not, baka pina-overhaul/repair na yan aircon ng auto mo tapos tinakpan yun intake duct for the fresh-air mode.
January 23rd, 2007 09:25 AM #3
2nd owner. it used to work. it was working before pinalinis ko yung aircon. didn't bother to check after. tapos ngayon ko lang napansin.
January 24th, 2007 11:17 AM #4
depende sa type ng ac meron motor ang actuator ng door (ATC), meron din vacuum solenoid . i check mo na lang baka me nahugot na vacuum hose kaya ayaw mag actuate ang fresh air door
January 24th, 2007 05:02 PM #5
I also have a problem with the blower of my aircon, everytime that i start my AC the air that comes out from it smells bad. Amoy basang basahan na naiwan ng ilang araw,
then after a minute the foul odor is gone.
Whattya think guys is the problem???
January 24th, 2007 05:07 PM #6
*t2erns
how do i do that? sorry di ako masyado marunong mangalikot ng kotse. my car btw, is a honda civic
January 25th, 2007 09:41 AM #7
not familiar w/ civic but in general yung outside air dumadaan sa cowl then papuntana sa ac housing meron door na nag bubukas or nagsasara para sa outside air yun door na yun ang most probable problem mo (not opening) ang control nito ay either electric motor (ATC) or vac solenoid (manual AC) usually nasa gilid ng housing nakamount ang mototr or vac solenoid, kaya depende sa set-up meron madali ma access meron din mahirap (some requires removal of the dash). since nagpaservice ka yata ng evaporator baka hindi naibalik yun lever kung, vac supply naman madidinig mo may hissing sound (pag nag open ka for outside air). since d2 sa atin hindi maganda ang environment you can leave it as ease wala naman mabigat na problem yan lagi naman recirc ang gamit natin. paayos mo na lang sa next service ng ac mo.
January 25th, 2007 10:04 AM #8
*vroom, when was the last time you had your air-con cleaned? baka mdumi na bro.
January 25th, 2007 06:03 PM #10
sir vroom
That musty odor is the result of microbial growth on the cooling coil. During normal A/C system operation, condensation forms in and around the A/C cooling coil. When airborne pollutants mix with this condensation, bacteria and fungi growth begins and odor results. kaya kailangan na siguro ng cleaning ac cooling coil (evaporator).
Tesla Philippines
