Results 1 to 10 of 35
Kratos4age help with radiator problem November 12th, 2012, 05:41 PM
1D4LV Re: help with radiator problem November 12th, 2012, 06:02 PM
Kratos4age Re: help with radiator problem November 12th, 2012, 06:18 PM
jvnj Re: help with radiator problem November 12th, 2012, 07:23 PM
Kratos4age Re: help with radiator problem November 13th, 2012, 01:25 AM
EVO-V Re: help with radiator problem November 13th, 2012, 12:05 PM
Kratos4age Re: help with radiator problem November 22nd, 2012, 10:32 PM
EVO-V Re: help with radiator problem November 26th, 2012, 04:26 PM
dr. d Re: help with radiator problem November 27th, 2012, 01:04 AM
EVO-V Re: help with radiator problem November 27th, 2012, 12:15 PM
dr. d Re: help with radiator problem November 27th, 2012, 07:00 PM
EVO-V Re: help with radiator problem November 28th, 2012, 09:58 AM
miked Re: help with radiator problem November 28th, 2012, 11:58 AM
EVO-V Re: help with radiator problem November 28th, 2012, 12:10 PM
LN106G Re: help with radiator problem November 28th, 2012, 11:27 PM
EVO-V Re: help with radiator problem November 28th, 2012, 11:55 PM
Kratos4age Re: help with radiator problem January 17th, 2013, 01:19 AM
doggieD Re: help with radiator problem January 19th, 2013, 06:07 PM
miko101130 Re: help with radiator problem January 20th, 2013, 07:54 AM
miked Re: help with radiator problem January 22nd, 2013, 10:25 AM
Kratos4age Re: help with radiator problem January 23rd, 2013, 02:29 AM
OniLord Re: help with radiator problem January 23rd, 2013, 03:32 AM
Chinoi Re: help with radiator problem January 24th, 2013, 09:56 AM
OniLord Re: help with radiator problem January 24th, 2013, 08:00 PM
EVO-V Re: help with radiator problem January 29th, 2013, 01:53 PM
raine Re: help with radiator problem January 29th, 2013, 02:29 PM
Ry_Tower Re: help with radiator problem November 28th, 2012, 10:30 AM
EVO-V Re: help with radiator problem November 13th, 2012, 11:57 AM
Kratos4age Re: help with radiator problem November 14th, 2012, 01:19 AM
EVO-V Re: help with radiator problem November 15th, 2012, 06:47 PM
dest Re: help with radiator problem November 18th, 2012, 05:57 AM
EVO-V Re: help with radiator problem November 18th, 2012, 12:24 PM
Kratos4age Re: help with radiator problem November 22nd, 2012, 10:30 PM
    Jul 2010
    Ano ba gamit mo sa radiator mo? Coolant or ordinary tubig lang. Every gamit ba ng kotse ay bawas kaagad ang reservoir?
    Kung maganda pagka Top Overhaul sa engine ay dapat hindi mag leak ang coolant sa loob ng engine.
    Jun 2012
    Quote Originally Posted by Chinoi View Post
    distilled water lang po, walang halong coolant..
    every week ako nagrerefill sa reservoir eh.. ok lang ba yun??
    kasi kung normal lang maglalagay nako coolant and tubig 50/50
    Aug 2005
    Quote Originally Posted by OniLord View Post
    There are very finite causes of leaks unless your radiator itself is damaged.
    Check the following:
    1. Inlet hose and attachments from the engine to the radiator.
    2. Outlet hose and attachments from the radiator to the engine.
    3. Radiator cap.
    4. Thermocouple O-ring.
    5. Overflow pipe.
    6. Water pump.
    If no leaks are visible, check your radiator for leaks, tanks, headers, core.
    If no leaks are found there's a good chance its leaking into your engine. So check your oil.
    Once you find and seal the leaks, flush and refill your system with coolant mixture and clean water.
