Results 1 to 10 of 14
- 10,620
- Jan 2003
- 5
December 19th, 2003 03:23 PM #2maybe the auxilliary fan has a problem.........if you need one we got some....
........we have a japan surplus shop...
give us a call, maybe we can help you out....
thanks
December 19th, 2003 03:39 PM #4
Baka yung carbon sa loob. It costs Php 400.00/fan sa aircon shop ni Mang Mario to bring them back to life.
He repaired mine and odell's.
December 19th, 2003 03:51 PM #6
Maari ding thermo switch. But that's pretty easy to check. Just hook your fan motor up directly to your battery. If it works, the motor is ok and the thermo switch might be at fault.
December 19th, 2003 03:59 PM #7
90% of the time its the contacts lalo na pag luma na yung auto.
But yes, you do have to eliminate all the possibilities. Automotive Troubleshooting 101
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 19th, 2003 06:34 PM #9
yung sa akin naman may naputol na wire going to the other auxullary fan, pag pinagdugtong mo aandar na yung fan... kaya pag-on pa lang ng oto ko umaandar na yung isang auxillary fan, then pag on mng aircon andar yung dalawa! san kaya dating naka connect yung naputol... nung tinrace ko yung naputol na wires, mayroon pa itong naka connect going sa ilalim radiator like a sending unit... and yung naputol, hindi ko alam kung saan naka connect!
BANNED BANNED BANNED
- 3,790
December 20th, 2003 07:42 AM #10tsarcol, i think that is thermal switch.....nag-oon lang dapat yung aux fan when the temp is too hot na that the main radiator fan could not handle it.
Kim, if its not the positive line or the motor brush, it could also be the ground contacts of the fan, baka nagloosen up na so hindi properly grounded ang fan.
hth
Tesla Philippines
