Results 1 to 10 of 35
October 18th, 2013 05:03 PM #1
ok lang ba mag lagay ng 2 auxiliary fan??nag inquire ako sa Twins Auto Aircon sa valenzuela 4500 daw dalawang fan Sanden brand....pano ba yon??mag lalagay daw ng wire sa compressor para sabay pag nag automatic ung aircon...ok lang kaya yon???btw for 2012 suzuki apv pala......no issue naman sa sasakyan I just want to put some extra fan for my peace of mind na hindi sya mag-init.
...or mas ok kaya na sa Denso nalang sa ako mag palagay since denso namn ang aircon at cooling system ng apv????
..thanks
October 18th, 2013 06:07 PM #2
I am not familiar with the APV, but I would assume that this is a front engined, rear wheel drive vehicle, correct? So apart from the engine driven fan, and the stock electric aux fan, you will still add two (2) fans more?
Over kill na ata sa aux fans yan?
October 18th, 2013 06:54 PM #3
It is a semi-bonneted van with a small 1.6L engine,,,,ung engine nya place under sa driver and passenger seats..pero ung radiator condenser nya nasa harap...ung radiator meron syang isang(1) dual speed na fan,when compressor engage the fan increased its speed...Im planning to put two(2) extra fan sa harap namn ng condenser kase may extra space pa between condenser and bumper..
October 18th, 2013 07:04 PM #4
I think it's unnecessary. Also, seeing that it's a new car, you don't have to worry about overheating for as long as you keep cooling system properly maintained.
I also think that you're likely to void the warranty if you do that.
- 53,883
October 18th, 2013 07:15 PM #6
baka lalo pang maging problema sa airflow ma ba-block lang ng fans ang airflow instead
October 18th, 2013 07:18 PM #7
kasya naman po sya,malaki pa ung space nila.....nakita ko po ung pwedeng ilagay na aux fan ung sanden brand na 10 blades medyo di namn sya malaki kaya kasya talaga,,,,,,,,,,,,,,,,,,,,,,I think sir oj88 you have a point..to be honest I never saw my temperature needle go beyond its normal operating temperature..I will ask na lang sa suzuki kung pwede if ma void siguro hindi na,pero baka pwede din silang mag lagay pag pwede sakanila na lng ako mag papa install ng extra fan?
October 18th, 2013 07:24 PM #8
October 18th, 2013 07:28 PM #9
October 18th, 2013 07:30 PM #10
