Results 21 to 30 of 184
May 7th, 2006 03:32 PM #21
Daming good reviews ang Evercool. Second choice ko iyan if we couldn't find a correct radiator for the vehicle we were restoring. Pero nakahanap ako, BEHR ang tatak. hehehe.
- Apr 2006
- 7
May 7th, 2006 03:53 PM #22Originally Posted by OTEP
SiRaNeko
- Jan 2003
- 973
May 7th, 2006 10:08 PM #24
BEHR is the OEM radiator for Benzes. AFAIK, it's made somewhere in Europe.
May 7th, 2006 10:16 PM #25
Tried it my past ride-Toyota Corolla, it's better than OEM coz its not plastic..After using the Evercool, didn't have problems eversince...
May 8th, 2006 12:56 PM #26
gregg_g: It's not better than OEM. Plastic radiators are not only lighter, they also give way to excess pressure to prevent more expensive engine damage (like cracked cylinder heads, for example).
FrankDrebin Guest
May 8th, 2006 01:07 PM #28
pag stock denso yung radiators nyo you can bring it to denso banawe pwede nila palitan yung plastic top or yung plastic bottom pag nag crack for 1.8-2k yata yun.
Yung sa CR-V kase made by Toyo yung radiator kaya wala yung plastic top replacement available
May 8th, 2006 06:28 PM #30
as long as di ka nagooverheat, there's no reason for it to break. The Denso thing isn't a repair, it replaces the whole top with a new denso top.
one reason why nasisira ang mga OEM radiator is kung binubuhusan ng tao (usually gas station attendants) ng malamig na tubig ang radiator while its still hot... kahit bakal magwawarp yan...
