Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
    Sep 2011
    #21
    free po ba check up ng radiator sa mga shops.
    Jun 2005
    #22
    Quote Originally Posted by chito2011 View Post
    yup. but expect na kahit walang sira they will suggest an overhaul dahil barado/madumi tubig/ mukhang may crack at kung anuano pa
    Sent from my Thrill 430x using Tapatalk 2
    Sep 2013
    #23
    i just saw that my radiator has rust in it. there's even a chunk blocking one of the pipes. you guys suggest replacing it?
    tubig kasi gamit eversince nadatnan ko yung vehicle, and that's 11 years ago. gusto ko sana palitan ng coolant (premix) kaso paano ba proseso nito?
    c
    Aug 2005
    #24
    In theory you can have that cleaned using a radiator flush. If that dissolves the sediments you should be fine. Replace with pre-mix coolant.
    Problem is when you "overhaul" you end up poking through the tubes and then risk abrading it, you'd be prone to leaks later and downtime.
    So the prudent sense is to replace the radiator.
    Jul 2011
    #25
    nice thread, kulang na la ng coolant additive package guidelines para sa all Al, Cu/Brass with lead solder.
    Posted via Tsikot Mobile App
    Aug 2005
    #26
    Quote Originally Posted by MrQ5 View Post
    Coolant additive packages are normally applicable for extreme and/or heavy duty applications.
    Any gains are marginal with the current long life coolants actually employed.
    For mixed metal coolant environments, stick with a glycol based coolant. Organic acid based coolants are more prone to cause nominal corrosion in the presence of a current.
    Aug 2012
    #27
    very nice thread. Part 4 na lang ang kulang.
    #28
    I have a seldom used 9yo kia picanto. My sister used it last weekend and experienced overheating. She said she noticed the aircon wasn't cooling for some time and later the red temp sign lit up. She Took it to the nearest gas station and they just topped up the radiator with regular water. The aircon ran back to normal and she was able to go home. I checked today the coolant reserve level and it is full so probably no leaks. It also ran fine this afternoon when I used it for an hour with a/c on.
    Should I have the coolant flushed and replaced? I'm worried the car might overheat again. I just bought 1L of abro ready mix coolant at a hardware shop (recommended over prestone). Is this enough? Can i just add distilled water? Planning to DIY coolant replacement tomorrow
    thanks in advance for your advise
    Apr 2014
    #29
    I flush mo na yan dahil nahaluan na yan nang tap water from the gas station.
    Normally, may knob kang pipihitin sa ilalalim nang radiator para madrain ang laman.
    #30
The Definitive Guide to Radiators
