Results 1 to 7 of 7
- Oct 2014
- 162
September 28th, 2016 06:35 PM #1Ajter 2 months from radiator overhaul, just found out the coolant reserved tank is empty while the radiator is still fukk. Is it normal? Do i kust only need tp replace the coolant reserved tank with the same mix (50-50)? Thanks.
September 28th, 2016 06:48 PM #2
Maybe you forgot to fill it after the overhaul?
At this point, all I can suggest is fill it with coolant (same ratio as what you put in the radiator) and observe.
September 28th, 2016 06:49 PM #3
Not normal.
Two possibilities:
1. You have a leak somewhere.
2. You need to replace your radiator cap.
- Oct 2014
- 162
September 28th, 2016 06:57 PM #4
- Oct 2009
- 2,271
- Oct 2014
- 162
September 28th, 2016 08:15 PM #6
- Jul 2013
- 2,450
September 29th, 2016 10:24 AM #7Just fill the coolant reserve tank then observe on a daily basis kung nagbabawas pa at kung gaano kadami nababawas.
Yung radiator cap nabibili yan sa auto supply. Hanapin mo lang yung tamang size at pressure rating.
Tesla Philippines
