Results 1 to 7 of 7
    Oct 2014
    Ajter 2 months from radiator overhaul, just found out the coolant reserved tank is empty while the radiator is still fukk. Is it normal? Do i kust only need tp replace the coolant reserved tank with the same mix (50-50)? Thanks.
    Jul 2006
    Maybe you forgot to fill it after the overhaul?
    At this point, all I can suggest is fill it with coolant (same ratio as what you put in the radiator) and observe.
    Aug 2004
    Not normal.
    Two possibilities:
    1. You have a leak somewhere.
    2. You need to replace your radiator cap.
    Oct 2014
    Not normal.
    Two possibilities:
    Thanks mga Sirs. I just replaced the coolant reserved tank bought from Casa.
    Oct 2009
    baka hindi na bleed..
    check mo din ung rad cap
    Oct 2014
    Quote Originally Posted by jaypee10 View Post
    Thanks Sir. Paano po yung Rad cap, palitin din kaya siya na. Paano po malalaman?
    Jul 2013
    Just fill the coolant reserve tank then observe on a daily basis kung nagbabawas pa at kung gaano kadami nababawas.
    Yung radiator cap nabibili yan sa auto supply. Hanapin mo lang yung tamang size at pressure rating.
Coolant Reserved Tank is empty. Is this normal? What is the implication?
