Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 59
    Jun 2012
    Nissan Sentra 95 Series 2- M/T B13
    Radiator Overhauled
    Cylinder head gasket replaced
    Hoses replaced
    But a while aago when I turned on my air-con after 1-2kms it overheated. Anything else that I need to look for that could be causing this?
    Aug 2004
    Full overheat, or just a small rise in thermostat reading?
    If it only happens with AC on, check your auxiliary fan. It might not be triggering. But that alone should not cause overheating.
    Jun 2012
    over-heat. as in kumukulo yung tubig sa reserve. tapos sobrang taas ng menor habang umiinit, yung hindi mo na kailangan tapakan ang silinyador.
    Dec 2007
    Hindi dapat kumulo ang coolant. One possibility is you have abusted head gasket which makes the exhaust gas escape through the cooling galleries, hence you have that bubbling effect. Pag ganito situation, uubusin coolant mo through the relief line. Yun lang kasi escape route and then issunod mga coolant hoses mo. Patingnan mo kaagad sa nagoverhaul ng radiator mo.
    Sorry, kapalit mo lang din pala ng gasket. Baka hindi tama ang lapat ng head. A simple observation will prove the above. Kung nauubos ang coolant and if you cannot see any other leaks that causes it, it might be as I explained above.
    Aug 2006
    check your aux fan if it will trigger during overheat. If not, something is wrong with the fan or its socket connector.
    I have experienced poor contact on the aux socket connector on my Lancer EX, same scenario after about 10 KM it will overheat and the aux fan is not working. Replacing the connector has solve the problem.
    Jun 2012
    Napansin ko lang nangyari ito nung nagpalit ako ng compressor ng air-con. Pinalitan ko na din ang hoses saka yung cover nh waterpump ata yun. Pero sabi nila yun yung waterpump.
    Jul 2012
    Pag naka-A/C lang ba nataas temp? Baka naman nag-high pressure iyong a/c mo.
    Jun 2012
    Panong nag high pressure? How to fix it?
    Jun 2011
    Quote Originally Posted by Drumz View Post
    it means barado or madumi condenser mo sir....
    Jun 2012
    Pero nilinis saka nag flush kami nung pinalitan yung compressor sir e. We also changed the valve dryer saka yung lalagyanan ng freon.
Overheat
