Results 71 to 75 of 75
August 11th, 2017 04:40 PM #71
- May 2011
- 481
August 11th, 2017 05:13 PM #72
Most of the clutch-less a/c compressor are that of variable displacement. The shaft turns everytime the engine runs, it operates by varying the angle of the swash plate to vary the piston/s movement or stroke which in turn vary the displacement to match the cooling load and cooling request. This was supposedly done to reduce the inertia of the compressor specially those cars with very small displacement engines and to get better fuel economy. These compressors are operated by the PCM.
August 11th, 2017 06:00 PM #73
Jodski: Nabaklas namin bro. Iyong replacement na motor pumapatak na P 1.9k. I opted to buy the oem motor w/c set me back P3.7k. At least siguro naman mas tatagal iyon kesa dun sa replacement
when you look into the abyss, the abyss looks into you
- 53,883
August 12th, 2017 02:45 AM #74
- May 2011
- 481
August 12th, 2017 05:36 AM #75
There will be a couple of diagnostic trouble codes (DTC's) and the system will not work right. It it not going to be plug and play. The clutchless a/c compressor is PWM ( pulse width modulated) at different frequencies while the traditional compressor is either on or off seconds or minutes at a time.
