Results 1 to 5 of 5
October 13th, 2013 09:35 PM #1
I need help pls. Experiencing problem with the temperature gauge. Actually pinagalaw ko yung temp gauge kasi pinalitan yung bulb sa loob so binuksan siya. After maibalik, lumabas na yung problem as illustrated below.
I brought it to Ceejays to have it checked and fixed. Unfortunately, kinalas nila ulit and opened the inside of the gauge, di nila naayos yung problem. Sabi ni Ryan of Ceejays is masyadong mababa yung idle ng vios ko kaya hindi raw nagengage yung compressor kapag hindi umaandar yung kotse. He is advising me to have an ECU reset or reflash kung di gumana since di naman daw sira compressor or yung magnetic clutch.
But the way I see it, what he said is a different thing kasi lumalamig naman yung aircon ko yun nga lang hindi dun sa setting nung gauge. My initial diagnosis is parang may misaligned sa loob nung gauge kaya hindi nadedetect yung proper settings ng temperature. Or may something faulty at hindi nagcome into contact sa loob. Now my problem is I don't know if I set my temperature to a maximum and quite bothersome din kasi baka maging cause ito ng overheat. Any inputs?
- Sep 2011
- 22
October 14th, 2013 11:17 AM #2hello po try nyo po i pa check sa rdc car aircon motor works sa kamagong st. makati para malaman po ang problem.
or text nyo po c ronald cp#. 09218059258..
- Jul 2010
- 570
October 14th, 2013 01:05 PM #3Baka misaligned pagsoli ng knob. Sana hindi na pwersa nun pagsoli ng knob. May key slot siguro iyon.
Bakit ang dami itinuro cause ng problem. May Reset ECU pa.Last edited by Chinoi; October 14th, 2013 at 01:09 PM.
October 14th, 2013 02:53 PM #4
Tama si Choi, na off-set lang yung pag kabalik ng knob from the OFF position. My guess it's off-set by 180 degrees. Hugutin mo lang then return the know 180 degrees rotated.
- 53,883
October 15th, 2013 02:55 AM #5
Tesla Philippines
