Results 1 to 7 of 7
- Jul 2003
- 41
January 16th, 2004 06:09 PM #1Mga peeps, May problem ako sa aircon ko, sana matulungan nyo ko. eto yung na-observe ko:
1. Habang nagdrive ako kanina bigla nalang nawala yung lamig ng aircon pero normal pa yung hangin wala lang lamig.
2. Pag naka idle tumataas RPM umaabot hanggang 2000 pero pag pinatay ko naman aircon switch, back to normal na rpm.
3. Yung isang fan sa radiator hindi gumagana.
Ano ba dapat i-check ko dito? Kaya bang i-DIY? kung hindi, san ok magpagawa banda manila? dito kasi ko sa Binondo area.
BTW: Honda City Lxi 98 yung auto.
January 16th, 2004 08:16 PM #2
1. Leak in your A/C line, kaya biglang nawala ang lamig malamang ubos na ang freon. My primary suspect is your evaporator.
2. One probable cause is the vaccum switch which automatically adjusts rpm when compressor is charging. Another case is an IC inside your hood (which I forgot what that name is), that controls your engine's rpm if it's an EFI.
3. Sunong na motor, pinapalitan ng either surplus or brand new motor.
Dalhin mo sa mga aircon experts they know what to do, expect to shell out 3-5K for an evaporator, 800 freon refill, blower cleaning, fan motor is around 350 for surplus to 800 for a rebuild unit. And other plus plus...
January 18th, 2004 12:07 AM #3
yep magastos nga yan! jst hope na o-rings lng leak nyan para makamura ka..
- Jul 2003
- 41
January 18th, 2004 12:55 AM #4Update ko lang,
Dinala ko kanina sa Sprint sa may shaw tapat ng cherry fudurama.
Una akala nila sira yung "magnetic wire daw" also known as compressor clutch. May short daw, kasi pag pinapalitan yung fuse nasisira kaagad, nung kinakalas na nakita nung repairman na may wire na naipit sa itaas ng compressor inayos lang yung wire and palit ng fuse, ok na. Buti nalang yun lang =)
January 18th, 2004 12:59 AM #5
Good thing it was a cheaper option. Btw, did they do something to prevent the wire getting stuck again?
- Jul 2003
- 41
January 18th, 2004 11:33 PM #6They just wrapped it with electrical tape and bent the metal that it got stuck with before. It's difficult to describe without a pic.
- 48
January 21st, 2004 04:01 PM #7sounds to me that hindi nag engage ang clutch ng a/c compressor mo... thats why mataas ang idle at nawala ang lamig... imho
Tesla Philippines
