Results 1 to 5 of 5
- May 2017
- 31
May 29th, 2017 06:17 PM #1Hello there,
Maybe guys you have an idea what is going on with my lancer 94. The idle goes up when i turn on the AC at the same time di lumalamig, di naikot fan ng aircon. Minsan gumagana AC pag bunuksan at di tumaas ang idle... pero pag nramdaman ko tumaas n ang idle, mwawala lamig ng aircon. Usually i turn off the AC then idle will go back to normal.. anu kya sira nito. Meron b need adjust lang? Or linisin or palitan.. i dont have any idea. Thanks.
- May 2017
- 31
May 29th, 2017 06:19 PM #2By the way.. may car is
Lancer 94
Sent from my SM-G610Y using Tsikot Forums mobile app
BANNED BANNED BANNED
- May 2017
- 210
May 29th, 2017 08:00 PM #3try to check your compressor magnetic clutch and bearing baka me problem na same issue on my suzuki apv
- May 2017
- 31
May 30th, 2017 03:07 AM #4I will sir thank you..
- Jun 2017
- 6
June 16th, 2017 06:23 PM #5Mga bossing pa-help naman po. Newbie here in tsikot. Yung 2009 hyundai tucson crdi ko nakita kong may bahid ng langis yung hose coming from compressor going sa bakal na connecting sa expansion valve. Sabi nila may leak pero malamig parin po ang buga ng A/C ko kahit 1 week ko nang nakita yung suspected leak. may slight hissing sound din sa loob pag nasa #2 or 3 sya. Ano kaya problem ng aircon ko. worried lang ako baka masira compressor ko Is this really a leak? Thanks Y'all!!!
Tesla Philippines
