Results 31 to 40 of 106
July 31st, 2013 06:27 PM #31
A reputable air conditioning shop can put freon and UV liquid like Spectroline. This is a dye that will appear where the leaks are making the task of finding the leak simpler and efficient. Determine where the leak is, seal it, charge up on freon and you'll have a cool car again.
Good luck!
July 31st, 2013 06:49 PM #32
For sure freon leak nga lang yan, i'd say wag na sa casa i doubt if they will entertain your warranty claim
Marami naman nag suggest dito sa board ng reputable ac shops.
Better have a comprehensive leak test hopefully oring nga lang ang dahilan ng leak para wala piyesa na papalitan.
Mahirap kung panay top-up ng freon, may altis kami na '05 twice nawawalan ng lamig twice ko pinakargahan ng freon due to leak. Di ko pinacheck kung saan, until one day bumigay compressor naubusan ng langis dahil dun sa leak na din. Mas napalaki gastos ko.
Sent from my GT-I9100 using Tapatalk 4 Beta
July 31st, 2013 07:09 PM #33
Wala pa nabanggit na shop e. Dalhin ko na lang sa Tower of David. But I will try my luck sa casa, isabay ko sa change oil. Inisip ko nga outside the casa na lang change oil ko e kakatapos lang ng warranty ng auto ko.
July 31st, 2013 09:45 PM #34
That's the best thing you do, if casa honor their warranty sa pag gawa nila ng AC mo before, then let them do it sabay na rin change oil.
if they don;t honor it, get it done by outside shop that can do the change oil & check auxiliary fan. If fan is working, then just top up the freon
first. From there on, time how long it loose the coldness. Pag na wala uli ang lamig, go look for a good & reputable AC shop. If they tell you to change
the expansion valve, make sure they change the dryer as well. Dapat sabay pinapalitan yan.
Lastly, if they charge you 9K for the AC fix, run away immediately and go to any appliance store. A 3/4 hp window type aircon cost only 8K.
Yun ang pakabit mo sa kotse, surely lalamigin ka na ng husto. :foryou:
August 4th, 2013 11:08 PM #35
Ano na nangyari sa AC mo cat? :what:
- Sep 2011
- 22
August 5th, 2013 01:18 PM #36
August 14th, 2013 04:38 PM #37
I brought my car to the casa na. They replaced the aircon filter but they said my ac will perform better if they can do cleaning but it costs 5k
My AC has not been cleaned since I bought it in 2010. Should I have it done?
Sent from my GT-N7100 using Tapatalk 4 Beta
"Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth."
August 14th, 2013 04:42 PM #39
Try Denso. Kalahati ata presyo compared to casa. Same din naman ginagawa. Pwede pang panoorin.
August 14th, 2013 05:06 PM #40
Ibaba daw kasi buong dash e. So I should have it cleaned na talaga kasi 3 yrs na e
Mahal naman ng AC cleaning. I thought it costs a little over 1k lang sa labas.
2 days daw gagawin sa casa.
