Results 1 to 10 of 174
- May 2019
- 12
May 19th, 2019 05:20 PM #1Ano po kaya pinaka the best compressor for lancer boxtype SL 4g33? Namamatayan kasi ako ng makina kapag paahon ang daan at naka on ang aircon. Salamat
Sent from my Flare S5 using Tapatalk
- 53,883
May 19th, 2019 05:59 PM #2i used to box lancer. as i recall, my compressor was factory-spec, which wasn't small.
i have not experienced what you are describing now.
my guess is, there's probably something with the engine that needs kumpuni-ing. my initial wild guess, is engine timing.
that, or the driver needs to work on his footwork.
good luck, king.
check also your current compressor. maybe there is something wrong with it, causing it to have too much drag.Last edited by dr. d; May 19th, 2019 at 06:47 PM.
- May 2019
- 12
May 19th, 2019 09:51 PM #3Okay sir noted papa check ko nalang po
Nararanasan ko lang po kasi mamatayan ng makina kapag paahon at naka on ang aircon pero kapag naka off naman ang aircon at paahon ang daan hindi po ako nag kaka problema o namamatayan ng makina.
Isang situation pa e yung namatayan ako ng makina along the way mga 30 mins na ako nag drive at naka on ang aircon traffic at tirik ang araw akala ko nawalan lang ako ng gas chineck ko naman ang fuel gauge kalahati pa so ginawa ko is pinatay ko na muna ang aircon and tuloy tuloy na naman na aking pag drive. Nag tataka lang kasi ako nung umuulan at naka on aircon ko di nanan ako namamatayan ng makina at wala naman problema. Sa tingin nyo sir dahil rin ba sa compressor to dahil hindi kaya ang load nito sa makina?
Salamat sir
- Jun 2005
- 3,774
May 19th, 2019 11:28 PM #4
- 53,883
May 19th, 2019 11:38 PM #5
- May 2019
- 12
May 21st, 2019 12:38 PM #6
May 21st, 2019 02:53 PM #7
That should be a solid ride bro...
Since you're checking the vacuum hose, pwede mong pataasin ng kaunti ang idle,- screw lang iyan na pipihitin...
Plus, you can advance the timing,- distributor lang iyan na medyo pipihitin....- (baka delayed kaya pumupugak kapag may load)...
- Jun 2005
- 3,774
May 21st, 2019 03:18 PM #8
