Results 1 to 10 of 19
- Oct 2004
- 132
July 19th, 2005 11:18 AM #1Just need your input guys what to do kc pag hindi on ang AC just above 1/4 mark ang temperature gauge ko... but if on ang AC napupunta siya and nag-iistay ng half mark pag nipatay ko ulit AC balik sa baba after ilang minutes. Is that normal? Is my radiator fan to weak or not having enough power due to the power drain ng AC? Kelangan ko ba improve and DIY ung negative wirings ko? TIA
July 19th, 2005 01:07 PM #2
what is your ride BTW, sa liteace ganyan din minsan over 1/2 and temp if ON ang A/C..
- Oct 2004
- 132
July 21st, 2005 02:33 PM #3Originally Posted by Innova_Boy
So I guess that's normal huh?
July 21st, 2005 03:47 PM #4
Kalampag please check if you have an aux fan for the aircon and see if it is working when your aircon is on. If it is working, something is wrong with your cooling system. Baka barado ang radiator or something.
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 21st, 2005 11:41 PM #5honda temps are usually always at the half mark. haven't seen one at 1/4th yet.
- Apr 2003
- 526
July 22nd, 2005 08:05 AM #6sobrang baba nga nung 1/4. 3/8 siguro basta under half pa yung normal sa akin.
check mo nga if both your fans are working. sa akin kasi ganito, with aircon off isa lang ang gagana na fan, yung nasa passenger side. with aircon naman both would come on.
hmmm, di kaya nakarekta yung mga fan mo and always on sya?
July 22nd, 2005 08:44 AM #7
Yaircon aux fan could be working, but is it turn at the right RPM? Baka mabagal na ang ikot.
July 22nd, 2005 08:49 AM #8
both my corolla experienced overheat just recently. Yung 91 GL ko, replaced the radiator fan, nag short nasunog. Culprit? Yung relay di na pumapalo. Cost me 650 for the fan and 350 pesos for the relay. Medyo napamahal pa yata ako sa relay, dun ko pinagawa sa Dong-Ver electricals sa may F. Manalo San Juan
Just yesterday naman, nag overheat din Yung GLi 97 ko. Di na gumana yung thermostat so ayaw mag circulate tubig. Had it removed. Sayang nga kasi the water and coolant are still factory-filled.Never ko pa sya pinalitan or dinagdagan ng tubig except yesterday.
- Nov 2003
- 3,848
July 22nd, 2005 10:03 AM #9pinatangal mo lang? have it replaced or you will lose effectivity in your cooling system.
July 22nd, 2005 01:10 PM #10
carlos, in addition to what miggs said, kung 97 oem pa yung coolant mo, long overdue na yan for flushing. 2 years lang usually ang regular coolant.
Tesla Philippines
