Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Apr 2003
    pag on ng aircon ko walang lamig. parang di nag-eengage ang compressor. thing is, galing lang ako kela mang mario for cleaning yesterday. kung nangyari to before eh di napacheck ko sana.
    ok pa sya nung pag uwi ko kagabi, meron bang fuse ang aircon system? or maybe may wiring na hindi naibalik ng maayos and nagloosen lang? checked the fans and ok naman sila.
    Jun 2005
    Baka loose connection lang. Ibalik mo kay Mang Mario for checking.
    Apr 2003
    yun nga problema, wala akong time dalhin dun.
    o nga pala, nagkabit din ako ng amp sa sounds ko. binaklas center console. may wiring ba dun na related sa aircon? di kaya may nagalaw? umiilaw n gumagana naman lahat ng panels ko
    Feb 2005
    baka nga may naputol na wire connected dun sa compressor..
    May 2005
    check all wirings connection regarding your AC
    specific wiring to check would be the single wire na nakaconnect sa A/C compressor (baka nakalas). Then sa center console, yung wires naman na nakaconnect sa A/C switch and A/C thermostat control. All these 3 wires will control the activation of the A/C compressor.
    Most A/C will not have a fuse but rather a circuit breaker so I doubt if it was a fuse problem.
    Sa Pajero may fuse iyan. Check mo na lang lahat ng fuse mo para sigurado.
    Kapag naglagay ka na ng bagong fuse at pumutok pa din, malamang magnetic coil na iyan.
    Pero check mo nga muna yung single wire going into the compressor, baka napatid lang.
    Dec 2003
    hindi kaya low freon? baka may leak? just a guess..
    Apr 2003
    Quote Originally Posted by BlueBimmer
    and the winner is... ang explanation sa akin, it works via a pressure switch so no/low pressure, no compressor.
    pinabaklas ko uli sa nearby aircon specialist layo kasi pag ibabablik ko pa.
    yung oring na nireplace wasak na. naipit ata nung pagkabalik. kala nung una nadobol yung lagay ng oring yun pala split in half na sya
    kunan ko ng pix next time, my fone cam sucks.
    Feb 2005
    so BB has the correct guess diagnosis.. galing talaga..
    dibale next time PM kita pag may problem rides ko... hehe..
aircon: compressor not running
