Results 1 to 10 of 36
- Dec 2007
- 181
February 8th, 2016 05:13 AM #1mga sir pa help po, yung hyundai grand starex ko kapag unang bukas ok naman ang aircon, sobrang lamig, pero after 15-30mins bigla na lang mawawala yung lamig, nung sinilip ko yung compressor nag turn on and off sya every 2-3secs. chineck ko yung aircon relay nya ok naman kaya lang may tick sound akong naririnig tuwing mag on at off yung compressor, malakas naman yung auxillary fan nya, pansin ko rin nung lumalamig pa sya hindi humihinto yung andar ng compressor, hindi sya nag automatic off kahit sobrang lamig na sa loob ng sasakyan, san po kaya problem neto mga sir?
February 8th, 2016 05:57 AM #2
Your system is short cycling. Have a tech check the both the low and high side pressures with engine at 2000 rpm. The low side should be between 28- 35 psig. If it is lower the low side may be restricted or the system under charged
February 8th, 2016 07:55 AM #3
check the line after the filter drier canister. if it is cold then you have a restricted filter drier.
check the sight glass. if there are bubbles then your system is undercharged.
if not these 2 then you probably have a defective temp sensor.
- Sep 2008
- 595
February 8th, 2016 08:38 AM #4It is also possible that your system is overcharged. Did you have your Aircon fixed lately, like charging the freon?
- Dec 2007
- 181
February 8th, 2016 02:20 PM #6maraming salamat po sa mga sumagot, update ko lang po, napansin ko ngayon kapag front aircon lang yung nakabukas ok sya hindi nag-off yung compressor, pero pag binuksan ko na yung rear aircon dun na sya nag off and on yung compressor, kapag pinatay ko ulit yung rear aircon and after 30secs to 1 minute ok na ulit sya. pinasok ko na tong starex ko sa hyundai north edsa pero di nila makita yung problema. kulang lang kaya sa charge ng freon or overcharge? or baka meron pa ibang pwede cause ng on and off ng compressor?
February 8th, 2016 02:59 PM #7
the best way is to do a pressure check i just mentioned. cut the rain dance. cut the guess work. observe the pressures when the event happens. check the static pressure and compare with the pressure/tempreature chart
Pressure - Temperature Chart for HFC-134a
- Dec 2007
- 181
February 8th, 2016 03:06 PM #8
February 8th, 2016 03:38 PM #10
ok pag front a/c lang pero short-cycling pag umaandar ang rear a/c? undercharge yan pag ganyan.
Tesla Philippines
