Results 1 to 10 of 13
September 8th, 2018 01:58 PM #1
Just got me thinking how does the aircon engage then disengage? is it time based or temperature based?
September 8th, 2018 03:12 PM #4
- Jan 2008
- 4,726
September 8th, 2018 03:34 PM #5
September 8th, 2018 03:34 PM #6
- Oct 2009
- 2,271
September 8th, 2018 06:09 PM #8
- Jan 2008
- 4,726
September 8th, 2018 09:26 PM #10
The duty cycle of the a/c clutch is subjective with the following factors considered:
Refrigerant pressure in the system,
Ambient temperature,
Cabin temperature,
Coolant temperature,
Control setting,
Throttle position sensor signal,
Sun load sensor signal,
Engine rpm.
There is no particular pattern unless your system is that of the old non-climate control system that relies on the a/c amplifier, or the pressure switch of the CCOT (cycling clutch orifice tube) type.
Climate control is a more precise localized temperature targeting.
In hybrids and electric cars, you dont have a compressor clutch and therefore you shouldnt be able to hear a clutch-like click on engagement
