Results 1 to 10 of 41
- Feb 2013
- 32
April 1st, 2019 11:35 AM #1Hello everyone, how true is this? (please see the video link below)
https://video.fmnl17-1.fna.fbcdn.net...=5CA2B5F5&dl=1
It says on the video that windows should be lowered so that the air inside the car (while it was switched off) will go outside. The air that was stored there especially during high temperature is cancer-causing (the mixing of burnt plastics and other chemicals). How true is this?
Video Link on Facebook: https://video.fmnl17-1.fna.fbcdn.net...=5CA2B5F5&dl=1
April 1st, 2019 12:11 PM #2
Personally, If the car was parked under the sun, I will open the windows for a minute of two para sumingaw yung init.
Sometimes I keep it open until I pay for the parking.
For those really hot days... I ask the intern to go down 30 minutes to open my windows
- Oct 2012
- 4,851
April 1st, 2019 12:18 PM #3Im doing the same... pero 1-2minutes lang...
- Jun 2015
- 2,751
April 1st, 2019 01:29 PM #4When parked under the sun, does anybody here open all doors (with windows rolled up) then closes the doors on one side to "push" the hot air through the open doors of the opposite side?
- May 2006
- 1,668
April 1st, 2019 01:35 PM #6
Another way to quickly cool down the cabin is to “fan out”.
-open passenger window
-open driver side door, open close several times (without latching the door)
- repeat five times
Works well for me
April 1st, 2019 02:05 PM #7
- Oct 2006
- 6,091
April 1st, 2019 02:46 PM #8I open all windows, put the aircon on fan, open the recirculate button to pull air from outside and drive for a few hundred meters before closing the rear windows. Fronts are left open till the temp gauge ticks up, and only then do I close the windows, close the recirculate button, and turn on the aircon.
Sent from my Mi A1 using Tapatalk
April 1st, 2019 02:59 PM #9
- Feb 2013
- 32
April 1st, 2019 03:08 PM #10thanks for the replies. however, the real reason I'm asking is - have you heard of that case (played/told on the video) re: cancer-causing agents?
I believe the video also told that there are still cancer-causing agents even if not parked under the sun (for e.g., at night). hence, at night, the windows should be open by the time you switch on the AC.
what do you think?
Tesla Philippines
