Results 11 to 20 of 20
November 28th, 2007 09:57 AM #11
buti naman ok na oto mo. samahan mo ko dun sa susunod. maingay na yung compressor bearing ko eh
November 28th, 2007 03:26 PM #12
glad to hear na may other solution sa problem mo, at least maliit lang nagastos mo. Yung 02 crv ko dati naka 2 palit ako ng compressor in 4 years!! lahat ng natanungan ko said that walang kwenta daw yung keihin na brand. takot naman ako bumili ng replacement at pa retrofit kasi baka in the long run masira din.sa frustration ko after the 2nd replacement binenta ko agad yung car
- Jan 2006
- 24
March 11th, 2009 01:27 PM #14Hi Sir, may i ask where is the shop of mang Mario? My compressor also stopped working on my 2003 CRV. I need to have this fox asap. Please advice me.
Thank you
March 21st, 2009 02:21 AM #16
sir try nyo po s EMPIRE COOL add.#2251 don chino roces ave mkati or Call Tel# 892-3494 look for Ronald or cris...
- Apr 2009
- 1
April 21st, 2009 12:59 AM #17Sira na rin ung compressor ko. Anong brand na compressor pwede sa Gen 2 crv? Keihin lng ba pwede? Til now hindi ko parin napapayos.Sa BF pque ako tumingin, compressor is 14K.Sirain tlga tong crv gen2. Hope u guys can help me.TIA
- Oct 2009
- 4
October 26th, 2009 11:59 PM #18Good day mga Bro... I have also Honda CRV 03 which have the same problem.. Im from pampanga medyo malayo sa manila but im willing to go kung saan man ung MANG MARIO na sinasabi nyo.. Pleasee Give me the Exact add mga bro.. Or sabi ng isang forum ito ba ung Mang Mario
146 Fort Santiago st, Bago Bantay, QC..
Pleasee.. Let me know mga bro.. Thanks po sa inyo
or email me: [SIZE=4]napster99*ymail.com[/SIZE]
- Feb 2010
- 1
February 9th, 2010 01:37 AM #19Hello,
keihin compressors for crv 2003 has been a problem not only by crv owners but also for most of the air-conditioning shops, most of the time the aircon starts to malfunction with busted compressor clutch coil, it is also true that the cause can be high pressure due to insufficient performance of both the radiator, and condenser fan.Regarding the clutch fan yes there are shops in banawe quezon city that specializes in aircon compressors,and surplus clutch coils are available , brand new clutch coils so far are not available, but you can ask for brand new replacement clutch assembly which includes the clutch hub, clutch pulley, and the clutch coil. Keihin compressors compared to most compressors are not as durable, they are highly sensitive to servicing, refrigerant and oil compatibility is most importantly to be consider, the system should be clean from moisture,and contaminants. The compressor oil should be highly miscible as specified in the manual to avoid compressor malfunction. Make sure that the right refrigerant is use in the system to prevent damage to the compressor.
Replacing most parts of the aircon sytem is highly recommended , this will now depends on the shop and the technician evaluation of your aircon system. however there is no guarantee that the problem will not hapen again. My best advice is to have your aircon check up by highly qualified technician, if you notice noise coming from the air-condition turn it off and bring it to the aircon shop of your choice.
- May 2019
- 1
May 13th, 2019 05:29 PM #20
Tesla Philippines
